Pre ignition MVT Millenium
sock
Message par sock »
Hello there!!! I have a question about the MVT Millenium 12 Volt CDI bleu ignition for peugeot 103: is the pre-ignition variable (calage à avant PMH)?
Lovecraft62840
Message par Lovecraft62840 »
The value is between 3 and 4,5 millimeters before the top dead center
51 G2
sock
Message par sock »
Is 3mm/4,5mm not to much pre-ignition for a 50cc?
No, it's OK for variable ignition
If not variable, it's 1,3
sock
Message par sock »
Can I use a MVT Millenium 12 Volt (CDI bleu) on a Peugeot 103 SPX from 1990 that originaly has a 6 Volt wiring loom (faisceau de câblage)? Or do I need a wiring loom of a newer type of Peugeot 103 SPX?
