Quelqu'un a-t-il trouvé une solution pour rendre le tuyau plus stable tout en lui permettant de vibrer ?
Je ne veux pas utiliser le joint à rotule Doppler car il est assez restrictif à l'intérieur.
Traduit avec www.DeepL.com/Translator (version gratuite)
i have made an exhaust pipe and mounted it rigidly to the cylinder. i have also added brackets to the the middle and front of the main pipe taken from the original exhaust mounting bracket. but due to the length involved the pipe wobbles or vibrates.
has anyone found a solution to make the pipe more steady but still allow to swing?
i dont want to use the doppler ball joint as it is quite restrictive inside.
IMG_3806 by alan jackson, on Flickr
