Pre ignition MVT Millenium
Hello there!!! I have a question about the MVT Millenium 12 Volt CDI bleu ignition for peugeot 103: is the pre-ignition variable (calage à avant PMH)?
Lovecraft62840
The value is between 3 and 4,5 millimeters before the top dead center
51 G2
